Hi does anyone have a early countershaft gear for a 1958 dexta, as you look at the gearbox from the front with the bellhousing off it is the large double gear on the bottom shaft. 55 teeth on the large gear and 28 on the small gear.
Just stripped mine and found 2 teeth missing!
You can't get the early gears any more, this woud mean replacing the whole ratio set or another gearbox.
I would like to keep the original gearbox if i could.
I'm based in Wales UK
