Breaking fordsons for parts
Early e1as x2 powersx2 dexta x1 07855315008 patrick
Re: Breaking fordsons for parts
Went to his yard today really nice lad had a good laugh and got a few parts for my dexta would recommend to anyone+he will post
Owner of a 1961 fordson dexta restyled model
Where are you?Patrick wrote:Early e1as x2 powersx2 dexta x1 07855315008 patrick
I have an E1A and the seat (the part that holds the ball joint in) is missing one side from my draglink. Don't suppose you have one. If not how much would the complete drag link be? I would need it posted because am based in Cambridgeshire.
Kind regards
Derek Watson
Kind regards
Derek Watson
Derek Watson
(deb.watson@homecall.co.uk)
Hi derek, would you have a lower dash panel for a diesel major kicking around? The bit that has the light switch and voltage regulator in it?
Hi Nick
No sorry - haven't got one.
Derek Watson
Do you have a pair of rear tyres 12.4 x 11 x 36? If so, how much do you want for them.
Derek Watson
I think i have a pair off an e27n. What condion are you after
Am looking for a reasonable pair as hope to use my tractor for competion ploughing. Tread can be down to 50% by the walls really need to be Ok with no cracking.
Can you help?
Can you help?
Derek Watson
no, these have about 20% with slight perishing on side walls.
sorry
sorry
Have you got the adaptor for fuel pump coupling available ? If so what size key has it got ?
Hi I'm looking for dexta parts I need a throttle lever and thermostat housing that bolts to front of block. You have any?
