What is better than an original Enfo jack?
Two Enfo jacks!
Seriously good jacks, stable with high reach, no sagging, no leaks. Havn't seen anything that compares. I liked the first one so much I hunted out a second.
The one on the left is clearly E27N blue, that on the right Empire blue. Were they in the tool kit with all new Majors? What about Dextas??
Enfo jack
Re: Enfo jack
nice one! I've seen this before on ebay among other tools. I'm always wondering if these are still usable.
Does anyone has a full set of the original tools?
Re: Enfo jack
Hi Mathias,
yep, if you can get one it is worth having in the collection/toolbox - very usable. I bought the second on a NZ auction site for equivalent of 12 euro (but had to add 24 euro for freight ).
If you look closely in the left hand side of the photo is a later version. Not as good as the earlier version - wobbly foot casting, and smaller footprint - although you can true it up a bit with angle grinder.
Neither of mine came with the original lever/bar, but a piece of steel rod lying around (3/4" / 19 mm ???) fitted perfectly.
Re: Enfo jack
Closer to you than me someone is collecting & collating Jack info, several pages (plus spanners!) you need to go a fair way down but the difference between E27N and E1A are noted
https://www.ozwrenches.com/jacks-OS.htm
HTH, there is a lot to be said for a properly designed screw jack
edit to add Lurking elsewhere on this forum
Assuming your tractor is a Diesel, the following is the Export Tool Kit.
N1725 Adaptor Water Ballast Valve
O1A17015 7/16x1/2 Open Ender
O1A17016 9/16x5/8 Open Ender
N17016 7/16x5/8 Wrench (Capscrew)
B17020 Screwdriver
N17021A or E1ADKN 17021 Adjustable Wrench
B17025 Pliers
N17029 Open Ender 2 3/16 Hex
E27N 17034 Handle Wheel Spanner
51 17035 Wheel Spanner
E27N 17080A Jack Assy
E1ADDN17098 Injector Lifting Bar
E1ADDN 17017 Open Ender 3/4
E1ADKN 17018 Key 1/2" L
N 17125 or E1ADKN 17125 Grease Gun
For Petrol or Kero Tractors add-
EOA 17017 Tube Socket - Spark Plug
E27N 17022 Screwdriver/Point Gauge(Magneto)
19E 17049 Tommy Bar
N 17079 Carby Jet Key
E1ADKN 17052 Pump (Spark Plug Air)
For Petrol or Kero Tractors Delete-
E1A DDN 17098
E1A DDN 17017
B17020 Screwdriver
B17025 Pliers
19E 17049 Tommy Bar
E1A DDN 17098
E1A DDN 17017
