Has anyone bought a loader for their Dexta recently? A niceone just went on the bay.
Does anyone know the evolution of Horndraulic loaders, the usual one for Dextas?
Most of them seem to look like mine with the frame mounted on back axle and under the engine:
However there appears to be a later version, more often seen on Ford 2000 and 3000(?) like this:
Note the sidearms have holes in their apex, maybe for lifting them on/off the tractor? The mounting frame is vertical, clearly very different. However, a quick check of measurements indicates that the arms are the same size and should be interchangeable with the earlier version. Can anyone confirm this?
Did Horndraulic make a vertical mounting frame for the Dexta?
I think the vertical mounting frame with struts to front axle is kinder on the tractor as it should reduce the bending moment trying to snap the skid unit in half at the engine/bellhousing. However with the older style frame, if one hangs a counter weight on the 3PL, that will reduce the weight on the front wheels and the bending moment on the skid unit at engine/bellhousing. So maybe the older frame is not so bad after all. The load on the front wheels will be the same with either frame, so there's no difference as far as the front axle is concerned.
Has anyone got a Horndraulic with vertical frame on their Dexta?
Dexta Loaders
Dexta Loaders
MIL Front Loader
That's goodjambug123 wrote:my loader is mounted round to the front axle and is a mill loader,it works well the steering isnt that heavy with 1/2 ton bag of gravel on the forks, which is the max it will lift with the standard hydraulics as the knock off valve kicks in if you try to lift more.
How does the frame attach to the front of the tractor?
Is it a standard frame for the dexta or did you have to mod it yourself?
Thanks,
Dexta front mounting
Just been looking at some of your pics. Is it attached using just the two lower rad mounting bolts?jambug123 wrote:the front of the frame mounts under the front of the rad with bolts with 2 uprights going to the frame.
I guess one could also attach it using the bolt that locates the front of the pivot pin (by fitting a longer bolt). That would take the load straight through to the pivot, where you want it.
All the best,
Front Loader Support
James, Thanks, that sounds robust. A photo would be interesting if you 're out & about with your camera.jambug123 wrote:it is bolted under the front axle support using 2 hi tensile bolts and covers the complete underside of this.
All the best,
