Source of grease seals?
Posted: Tue Feb 02, 2010 9:22 pm
by Chris Ivin
I need to replace the axle grease seals on the Bamfords tipping trailer I am restoring. I have tried the local seal shop and they don't seem to have anything to do with grease seals.
Can anyone suggest a source?
Posted: Tue Feb 02, 2010 11:22 pm
by Tubal Cain
Posted: Wed Feb 03, 2010 9:40 pm
by Chris Ivin
Thanks Gerald,
I emailed them this morning, and they said "If the outside of the seal is tapered we wont be able to help, its a bespoke part as all standard seals are parallel outside". This is much the same as the local bearing/seal shop said.
The seal I'm after sits stationary on the axle shaft with the seal formed on a vertical face on the brake drum rather than being fitted in the brake drum itself and sealing on the shaft. Is this the normal form of grease seal in this situation?
Posted: Wed Feb 03, 2010 10:17 pm
That is a similar design seal to the '000nd series front wheel bearings.
A lot of trailer wheels and running gear was imported from companies in Italy by a large company here in Dereham. They are now out of existance but I have a feeling that someone set up selling parts. I will ask around later this week.
As a possible lead, try a phone call to Bunnings of Gresenhall, East Dereham. They make trailers, muck spreaders and the like and may have contacts.
Posted: Thu Feb 04, 2010 8:12 am
by Chris Ivin
Thanks Brian,
I'll give Bunnings a try.
