the wear plate sits under the back of the blades and behind the bar the blades attach to? ill see if i can make something to fit to replace the worn ones. thanks for explaining i am new to all this.
made some new wear plates. but the blades still dont touch the ledger plate, where do i need to add/remove shims? do they go under the clamp plate or under the wear plate?
