Posts: 2666 Joined: Mon Sep 15, 2008 12:59 pm
Post
by Bensdexta » Mon Sep 27, 2010 11:16 pm
Is anyone got a small woodprocessor?
Eg a Hakke Pilke Eagle:
It runs off the PTO 10hp requirement, has a 700mm circular saw blade which can cut 10" dia logs. It has a 4" screw splitter, but no conveyor between the two, ie it's manual transfer. Cost appears to be £1200, not hugely greater than a Ferguson cordsaw + splitter.
Any advice appreciated
woodseaves
Posts: 122 Joined: Sun Jun 27, 2010 12:46 pm
Post
by woodseaves » Tue Sep 28, 2010 10:25 am
£1,550.00 Plus VAT From :
Davies Implements Ltd
Blaenteg, Trevaughan, Carmarthen, SA31 3QN.
Tel.: 01267 237726
www.daviesimplementsltd.co.uk
Supermanuel
Posts: 53 Joined: Wed Sep 22, 2010 7:07 pm
Post
by Supermanuel » Fri Oct 01, 2010 4:10 pm
I hv a JAPA 600. Max dia 300 mm, splitting in 2, 4 or 6 pieces with 3,2 m conveyor.
Without conveyor much slower and with it you can load directly on trailer. I consider it as highly recommendable.
http://www.japa.fi/index.php/klapikoneet.html
New Performance Super Major Manuel 08D970466
Post
by Bensdexta » Fri Oct 01, 2010 4:42 pm
Supermanuel wrote: I hv a JAPA 600. Max dia 300 mm, splitting in 2, 4 or 6 pieces with 3,2 m conveyor.
Do you run it behind your Major? Have you a pic?
How many tonnes of wood do you process each year?
Thanks,
