Posts: 2666 Joined: Mon Sep 15, 2008 12:59 pm
Post
by Bensdexta » Sat Oct 05, 2013 10:20 pm
Has anyone tried these on their Dexta or Major?
http://www.northerntooluk.com/agricultu ... cification
I'm not quite sure how you get the lift arms at the correct spacing for your implement without getting off?
Think you can still use a stab bar.
Any comments appreciated.
tom lad
Posts: 447 Joined: Tue Oct 05, 2010 2:53 pm
Post
by tom lad » Mon Oct 07, 2013 9:06 am
Bensdexta wrote: I'm not quite sure how you get the lift arms at the correct spacing for your implement without getting off?
me neither m8
cant see its worth the money tbh
Post
by Bensdexta » Mon Oct 07, 2013 9:49 am
tom lad wrote: Bensdexta wrote: I'm not quite sure how you get the lift arms at the correct spacing for your implement without getting off?
me neither m8. Can't see its worth the money tbh
There's an adjustable spacer that you can use to set the width, just visible in the vid:
http://www.youtube.com/watch?v=qYM0bOSBVJ8
But I'm inclined to agree, prob not worth the money. A quick-hitch A-frame is another option, but implements may have to be altered to match width etc.
One other point, such devices will reduce lift capacity slightly because you're moving the weight further back.
Mjg1705
Posts: 188 Joined: Fri May 11, 2012 9:44 pm
Post
by Mjg1705 » Thu Oct 10, 2013 11:12 am
They seem a good idea but are far too expensive - for that cost you could buy some old hook end lift arms ant fit them to a major for example - anyone ever tried doing that ?!
