I will need an engine crane to remove/install the engine in my Dexta. I gather that a complete engine with
- block + waterpump
- head
- injection pump
- flywheel
- clutch
weighs up to ~400kg. Can anyone suggest a suitable crane, eg half ton Clarke Strong Arm? What cranes are others using?
Many thanks,
Ben
Engine Crane for Dexta
- Site Expert Team
I would go for a larger crane, I have the Clarke "Long Reach Crane" code 020110145 it will give you greater scope. Bear in mind that the max'm load is at min'm reach.
The crane requires to be used on a smooth surface, as you will find it difficult to move when lifting the engine on a rough uneven surface.
Gerald
Gerald
Here is what I use.Bensdexta wrote:What cranes are others using?
Many thanks,
Ben
http://i179.photobucket.com/albums/w315 ... /003-3.jpg
http://i179.photobucket.com/albums/w315 ... /006-1.jpg
ENGINE CRANES
All,
Thanks for the info. Front loaders have their uses!
Fortunately I am working in a garage with concrete floor.
All the best,
Ben
Please confirm that this crane doesn't fold?Tubal Cain wrote:I would go for a larger crane, I have the Clarke "Long Reach Crane" code 020110145 it will give you greater scope. Bear in mind that the max'm load is at min'm reach.
Gerald
All the best,
Ben
- Site Expert Team
