questions re. the pto on my howard rotorvator
the shaft is too long , I have to run it with a very long top link so I doesn't bottom out , don't think this is a good plan.
it does about 45 mins work a year for me on me veg. plot . ( prob 20 yard / meter square )
if I worked it for hours it would probably fail some were but it doing my job.
the shaft is splined , many splines prob 20 + , I thought all ptos pulled apart and then you can chop a lump of to shorten , my local agri. dealer agrees . this one is captive together , it telescopes but wont separate , ??
I cant decide if there is a collar to unscrew .
I was going to buy a new guarded shaft but his books didn't have one. vapormatic books. I have not researched online yet
the gearbox end has a spline and a parallel boss which sits in a oil seal , retained with a roll pin , not just a standard spine .
is advise is to keep the gear box end yoke , fit that to a new shaft which he cant source ! good plan if I can get one ?
if I can shorted it by about 1" , 2 " would be better then it will prob live for now
post photo soon
tom
