So we got the tractors home with no problems, other than it took 4 hours to get them loaded and tied down. The one that looks like a pile of parts wouldn’t move, the brakes were locked up tight and after a lots of swearing and sweating we decided as the front ax was only attached by the power steering cylinder, we took it and the rear wheels off and pick it up with the skid steer and load it on the trailer. When we got to the power major we found one rear tire was split open and the front axel was only on by one pin, apart it came and was picked up and loaded on as well.
Three hours there, four hours to load, and three ours back, got everything unloaded, got the trailer back, and it was time for bed. It was a long day but a good one.
I’ve been working on the Super that runs, we drove it on the trailer, but it does have some issues. No hyd pressure at all and the screen is clean, maybe a bad pump, sheared key, broken line??? I drained all the old fuel out, cleaned the fuel pump and put in a new fuel filter and it runs reasonably well but misses and smokes some, and hard to start. If the three point worked I’d put a plow on it and work it for a while to see if that would help. It has 20 psi oil pressure when warm, nothing to bitch about.
Now that I have them home I have started to look things over and check the serial numbers on all of them and found that the Super with the loader and the “pile o parts” Super are only 10 digits apart, probably made on the same day and probably sold at the same dealership over by Eau Claire where I picked them up.
And I know what you’re thinking….is Pat going to take one running tractor and a good running free one from his uncle to make a Doe, or is he so anal that he is going to take one that may be good or may be bad, and another one that is obviously a pile of scrap to make a Doe only because the tractors were made the same day……..Yes Pat is that anal!
It looks like I have some work to do, and Granny is pissed already.
When I pulled in the yard and got out of the semi, I walked over to her, pointed to the lovely load on the trailer and exclaimed, Happy Anniversary Honey”…..she didn’t think that was very funny.
These tractors all have 30" rears and I will use them on the Doe, I belive the four Doe's that were sold in the US all had 30" as well.
Pat
