jcb brakes
Posted: Fri Jun 12, 2009 10:02 am
by mark white
I am doing the brakes on my 1977 jcb 3c II. Not sure if it based on a Nuffield or Leyland skid unit? What is most likely?
It has the 4cyl engine with the simms injector pump and mechanical governor. I need to scrape off layers of yellow paint to get to the engine number.
The brakes are very similar to the Super Major. Dry disc brakes.
I have started to strip them down, the linings need replacing and are bonded to the metal rotating disc. I have seen just the linings advertised, but it would be easier if a company did exchange friction discs, or I may have to send them off to be relined?
I can't fully strip one side as the linkage is partialy seized by the adjusting nut, the nut is off but I can't get the sleeve thing off the operating rod ( just in front of the dust rubber). I have left to soak and will have another go saturday.
I also need another Clutch pedal and probably brake pedal return springs.
Any help or suggestions welcome, sorry for the long post!
Posted: Fri Jun 12, 2009 1:09 pm
Mark,
If it is 1977 it will be a Leyland. They have similar brakes to the Super Major but have different splined hubs so are not compatible.
I would rather use riveted discs than the stuck on type. I have had problems with them on my Nuffy when the discs have come unstuck off the hub. I have now got riveted ones and these are much better.
I got mine from M.Hipperson, Downham Market , he is on E-Bay and I can really recommend him. You will need to return the old discs.
Posted: Fri Jun 12, 2009 1:48 pm
by mark white
Hi Brian,
Thanks for the reply.
If they are bonded, I guess the rivet holes would be underneath, can't see at the moment.
I have bought things off of Malcom before and he is very very good I will give him a call.
When I eventually get to the rebuild, is it best to leave the actuators plates / balls and splines dry or apply a smear of copper grease?
Posted: Fri Jun 12, 2009 6:31 pm
I am depating that myself! I cleaned mine up about a couple of months ago and applied a smear of MS3 grease to balls and splines. One brake works perfectly and the other grabs like mad so its back to the drawing board.
I have heard that you can get a dry graphite to apply but have not seen anything yet.
Posted: Mon Jun 15, 2009 4:26 pm
by mark white
If my JCB is based on a leyland skid unit what model is it likely to be based on
My tractors have only ever been Fordsons,or the others I have being grey, starting with a 'F' but I won't mention the name
I have now got the offside apart, the linings are riveted on that side
I also now have an oil seal to do as the seal is starting to leak. Quite ironic as the best brake was the one with the leaking seal
I have used a smear of copper grease on both super majors of mine in the past. Just applying a smear to splines and balls, It has stopped the brakes sticking on, which one of them has been prone to.
Posted: Mon Jun 15, 2009 7:32 pm
Will try the Copperslip and see what happens.
Not sure which Leyland you have under there. Up to about 1969 it would have been the 4/65. Is it a three or four cylinder?
Posted: Mon Jun 15, 2009 8:13 pm
by mark white
It's the 4 cly non turbo, with a simms mechanical governor injector pump.
I have found the engine number, but need to scrape off layers of thick yellow paint first
Posted: Wed Jun 24, 2009 5:36 pm
by dexta4
prob be a leyland 384 they were a common skid unit ?
Posted: Fri Jul 03, 2009 7:54 pm
by essex pete
It may be the 4.98 type engine with about 65-70 hp.
So would that have made it a 272??
Posted: Sat Jul 04, 2009 10:55 am
by mark white
I must scrape off the paint and find the engine number, but thanks for the suggestions.
Posted: Sat Jul 04, 2009 3:25 pm
Mark,
Its right at the back on the right side looking from the seat, on a flat area machined onto the block. Unlike Fords, you have to get over the top to see it and the head tends to get in the way.
