Potato Harvester parts.
Posted: Mon Sep 28, 2009 4:55 pm
I was checking over my harvester a few days ago and found a bearing faulty.
Bearing in mind that this is a Johnson harvester, made in the 1950's to early 1960's and the company has been out of existence for at least 40 years, what do you rate my chances of getting one?
Yes you've guest it! They were off the shelf!!!
Posted: Mon Sep 28, 2009 7:23 pm
by John
In fact, if you have the bearing spec., any bearing factor should be able to supply one. The same bearing could appear in any number of applications and machines.
