OK Guys,
Here's what I can find, please check yourselves for verification...
Allis Chalmers started to produce tracked machines. Their big 'claim to fame' was that they came up with a design of tooth for the drive sprockets that dramatically cut down on wear.
They decided to call this design 'Hunting Tooth' and so, all of their crawlers were given the prefix 'H' for 'Hunting Tooth' drive sprockets.
They also offfered the choice of Gasoline powered or Diesel powered so...
H6 = Hunting Tooth drive sprockets, Gasoline powered.
HD6 = Hunting Tooth drive sprockets, Diesel powered.
That's deduced from a 'crawl through' on the web. (Oh! the guy's a comedian as well
What is definate is that 'D' is Diesel and no 'D' is Gasoline.
What was deduced, after MUCH reading, is that the 'H' denotes this low wear 'Hunting Tooth' design on the drive sprockets.
Reasoning - Can't find ANY 'H' prefix before they announce this low wear sprocket design, then they give it the marketing name of 'Hunting Tooth', then the 'H' prefix starts to appear.
Could be wrong, please check.
Must go and sit on my Major now, all this talk of others makes me feel quite poorly.
Mike
