Hi All
Well mine is home now too!
Had her delivered yesterday by a nice and friendly local plant hire company at a resonable price. My first quote was over £400 to move the machine 8 miles which I thought was a bit excessive
It didn't start very well, even when warm. The previous owner had told me he used to give her a sniff of easy start when cold starting
Anyway after a bit of looking around her at home in more depth, she has a 'simms pump,' with the cold start pressed she starts straight away. I will try her from cold in a few days to see how I get on. On the dashboard there is a small resevoir with 'starting pilot' marked on it, also a small pumping plunger on the steering column,What fluid would go in here
There also appears to be a heating plug in the inlet manifold.
As this machine is totaly alien to me, and the wrong colour
I have been trying to get hold of a drivers manual or maintenance manual, but no luck yet.
The engine is 4cly leyland, but I can't see any numbers due to the yellow paint. There is a number on the cab, but a bit faint. There are a few jobs to do mainly wiring, but first seeing if the heater plug works and I taped up some bare wires already.
I have had a little play, and a few elderberry trees my dad has been moaning about are now moved with ease
I will have a go at posting a picture later if you guys would like to see
