US Ford
Posted: Fri Dec 20, 2013 10:10 am
Re: US Ford
Posted: Fri Dec 20, 2013 2:40 pm
by Dandy Dave
Nice Film Brian. The Golden Jubilee is an NAA Model. I have rebuilt and worked on my share of these. The hydraulic pump was changed from a gear type to a piston type in later years. Gear pump parts are Not Available any longer. Had a customer with one with a spun rod bearing a number of years ago. I ended up rebuilding the motor and restoring the whole tractor. He is still using it in moderation on his gentleman farm. Many of the features shown of course are options. The Live PTO is a rare one, as well as the double acting remote cylinder valve. It was a much better tractor than the 9N,2N,8N series, But I would not give up my Power Major for one. I would compare the tractor to a TE20 Furgy. It uses about the same fuel as the petrol model and is about the same size and power. Dandy Dave!
Re: US Ford
Posted: Sun Dec 22, 2013 9:38 pm
by Pascal
Hi Brian,
A friend of mine has one. When you are in Holland again, I am sure he will let you drive it.
