Pascal's article about installing a raised PTO added!
Posted: Wed Apr 30, 2008 6:41 pm
by Oscar
Chaps,
Some time ago Pascal sent me an article with photos about installing a raised PTO on his Major. I've added it to the Wiki, you can find it
here.
Pascal, can you check if I made any errors?
There are very good pictures in this article too! Enjoy it!
Regards,
Oscar
Posted: Wed Apr 30, 2008 7:36 pm
Great article Pascal! Very well done
Posted: Wed Apr 30, 2008 7:44 pm
by jambug123
that is a very good article Pascal a very good read.
James
Posted: Wed Apr 30, 2008 8:29 pm
by Kiwi Kev
Pascal
Good article. Had'nt thought about pumping the oil out of the rear transmission.
Kiwi Kev
Posted: Thu May 01, 2008 8:20 pm
by Pascal
Hi Oscar,
Thank you for placing the article. It looks great in the Wiki!
Best regards,
Pascal
Posted: Fri May 02, 2008 7:17 am
by Oscar
Hi Pascal,
If you see any errors in your article or if you want to make any changes, just click the edit button, make the changes, and hit the save button
Regards,
Oscar
Posted: Fri May 02, 2008 6:26 pm
by henk
Well done Pascal,
Pictures tells so much more.
Posted: Tue May 06, 2008 11:25 pm
by Roadless63
Great article indeed, a word of warning regarding the use of instant gasket/liquid sealant - less is often better than more! Imagine that however much is squeezed out on the ouside of the joint is dropping off into the insides too! A bead of sealant which gets squished down to a few thou thick has to go somewhere! Engine sumps are a favourite problem area, with bits of sealant blocking up the oil pump pick up strainer resulting in ruined engine.
Posted: Sun May 11, 2008 11:57 am
by Aussie Frank
Hello Pascal,
That is a great article about fitting the raised PTO. I have always wondered if a raised PTO would fit on an E27N. I have an E27N fitted with a P6V engine that is good for 80 HP at 2400 RPM but I can't use it because I need 540 RPM on the PTO for most things. A raised PTO would solve most of that, but I have never seen how they get fitted. OK before I get the howls of protest about modifying my tractor I will say that everything that has been done can be unbolted after her working life is over, and I plan to keep her after that and put her back to standard, but some extra PTO HP would be good at the moment. Probably won't be an issue because raised PTOs seem to be as rare as rocking horse poo and my grandson's rocking horse seems to be toilet trained.
I will however say that Roadless is absolutely right about instant gasket. You won't have too many problems with the back end of your tractor but I have found that it is a temporary seal at best. Many years ago when I was very young I watched a mechanic make a gasket out of gasket paper by sticking it onto the mating surface with grease and tapping out the profile with an engineering hammer around the edges. 40 years later I know that gasket does not leak because it is sitting in my back yard on my other tractor. I can't say the same for a lot of my later efforts with instant gasket.
Regards, Frank.
Raised PTO on E27N
Posted: Mon May 12, 2008 8:05 am
by Emiel
Hello Frank,
The raised pto won't fit to your E27N because the gearbox on a new major is longer, so the internal pto shaft is longer as well.
Cutting and welding an old new major axle to shorten is is not good, because of these are very rare and not to be destroyed.
Posted: Mon May 12, 2008 9:39 am
by Aussie Frank
Hi Emiel,
Thanks for the information about the PTO shaft. I just assumed they would fit because I have seen E1A Major hydraulic lifts fitted to E27N Fordsons. I know the bottom plate on the rear end interchanges so you can fit the hydraulic pump and I know you have to change the shaft so that you have the drive gear to drive the pump. I didn't know the shaft length had to be changed also to make it all work. Not that it would have happened in a hurry, but I think you have just saved me a lot of gear oil and a lot of frustration.
Regards, Frank.
