Right! Sorry for the long inactivity but I'm Back!
Some news.
Looks like I would need the "Turn Over You Swine" Battery fluid. Our Ford 5000's Battery is near the end of its life. Doesn't even have enough to turn the engine over compression. Looks like we have to buy the battery named "There You Go You Have A New Battery You Bastard" but I think the label wouldn't fit in the battery itself.
As a result, we had to do what farmers here in our province at least, used to do. if they don't have the time yet to buy a new battery they would park their tractor at an incline, pointing downwards, usually they would park it at the side of a dike, a hill, etc. tThe bad thing is, and this happened to my father once as far as I could remember, if you tried to bumpstart your tractor, rolled it down the hill while in gear, with the foot on the clutch pedal, then when the tractor picked up some speed, released the clutch but by the time the tractor ground to a halt at the bottom of the incline the tractor hadn't started yet
So now the tractor is currently parked in its garage, which is at the side of a dike, and since for export tractors normally doesn't have a handbrake, the tractor is held in place by a wooden wheelblock at the rear tyre(when I say Wooden wheelblock I actually mean a big chunky part of a branch of a fallen tree)and, as an assurance that the tractor would not by chance run the block over and come rolling down the incline, it was left in gear because the brake pedal lock on our tractor had been long lost, just like every single tractor on our place.
