Something we need to clear up after Doris.
Posted: Sat Feb 25, 2017 4:08 pm
Re: Something we need to clear up after Doris.
Posted: Sun Feb 26, 2017 1:01 am
by oehrick
Dont let NRO or the Grid know, they left enough cr@p last time through, and NRO don't even pay wayleave
Anyhow, did you see what you missed in the right hand column Brian ?
https://www.youtube.com/watch?v=ZTCCdnKJPJY first clip, Empire Blue and Rotopeds............
Posted: Sun Feb 26, 2017 9:42 am
Do you know Rick, I have never seen a set of Rotopeds like that. Most of the ones I came across were packed with frozen mud and detritus!
Posted: Sun Feb 26, 2017 11:50 am
by oehrick
I can understand that Brian
I'm always amazed that they lasted long enough to be worth the investment - the Boydell equivalent used on the likes of Burrell traction engines were notorious for fast wear.
They look like overkill for that Tarmac!
Posted: Sun Feb 26, 2017 4:46 pm
I have mentioned before the customer we had at Necton who had his NP Super crown wheel changed every year to a low speed for winter ploughing and then back to a high speed for summer work, well she used to be on Rotopeds with a three furrow Lemken revesable plough all winter. I can remember going out after her and the County crawler on the field where they are now building the new sub-station for the North Sea cooling fans.
That is very heavy land, good for wheat growing but it was a struggle for those two to work. Funnily enough we never got any problems from the Supers back end when working on the Rotopeds.
Posted: Mon Feb 27, 2017 1:09 am
by oehrick
Unlike modern 'designers' seem to imply, it doesn't always have to look good or right to work well I suppose Brian.
I've convinced more than one person who ought to know better that the 'fans' down on Eye airfield are to blow the smell of the chicken s%!t fired power station away from Suffolk and onto Norfolk
Any inside knowledge on that Adrian ??
Been chain sawing a route for the Major toward the pair of Chestnuts I want to drop before they leaf up again this afternoon, Im sure there are a lot more Spruce & Birch laying across it than there were last weekend.................
Major success on Friday, the random stopping of the Swedish Brick (which I thought I had cured before Xmas) struck again, pretty sure I've found and fixed it now - a badly crimped wire giving enough conduction to trick a multimeter but not pass 20 amps for the fuel pump - showed it how I crimp a wire!
