Page 1 of 3
Temporary Test Post
Posted: Sun Feb 08, 2009 12:44 am
by Mike Kuscher
Oscar, Brian,
Testing again.
Can you see this picture?
Testing suspended. Method unsuitable. FTP server closed down.
Mike
Posted: Sun Feb 08, 2009 10:28 am
What picture Mike?
Roll Bar
Posted: Sun Feb 08, 2009 11:29 am
by Bensdexta
Mike,
I can!
BTW what make of roll bar do you have on your Major?
How convenient is the folding mechanism?
Thanks,
Ben
Re: Temporary Test Post
Posted: Sun Feb 08, 2009 2:02 pm
by Oscar
Mike Kuscher wrote:Can you see this picture?
Yep! I sure can
Posted: Sun Feb 08, 2009 2:26 pm
Must be me then. I can see nothing but the words.
Posted: Sun Feb 08, 2009 2:29 pm
by Mike Kuscher
Oscar, Brian,
Need to do some more checking.
It seems to be randomly dropping the wifi link.
We 'battle on'.
Oscar, try seeing if you can 'post' something.
Ben,
Regarding roll bar...
Don't know. It came with her and I can not see a manufacturers plate.
Needs some attention, when I get around to it. Folding joints need the pins freeing off.
by henk
I can't see it also, even when I try to follow the link.
The topic is loading real slow so I think it's searching on the net, but can't find it.
Posted: Sun Feb 08, 2009 7:59 pm
Mike,
The link that Henk mentioned does not show up on my computor.
Posted: Sun Feb 08, 2009 8:45 pm
by Pascal
Mike,
I don't see the link either. The post takes quite some time to load.
Eventually I see (in stead of a picture) a white square with a red cross in it.
Posted: Sun Feb 08, 2009 8:52 pm
by Kiwi Kev
Mike
I'm with Pascal
No link, very slow and white square.
Kiwi Kev
Fordsonlad ?
Posted: Sun Feb 08, 2009 9:31 pm
by Bensdexta
Mike,
What is "
ftp://fordsonlad.dyndns.org"
Is it you
Thanks,
Ben
Posted: Sun Feb 08, 2009 11:47 pm
by Mike Kuscher
Oh Dear!
As I've said, seems that the server is randomly dropping the wifi link.
Trouble is, I don't know why yet.
Will keep 'plugging away'.
Let's try this...
Posted: Mon Feb 09, 2009 4:43 am
by commander
Mike, when I first opened this topic, the pic in the first post loaded very quickly...the pic in the last post did not load...I had a msg in my browser (firefox v3) that ftp transaction was finished....when I hit the 'reload' button, both pictures appeared.
For the other folks that are curious....DYNDNS.ORG is a service that allows you to have a name .... "www.something.dyndns" ... name associated with your IP address......I believe Mike is attempting to link directly to photos stored on a home or office computer instead of using photobucket or the like ....
( I used to be a bit of a computer nerd myself ..been out of practice a few years though)
Posted: Mon Feb 09, 2009 7:58 am
Chaps,
Mike is working on our own dedicated photo page so that we don't have to use Photo-bucket et al.
That is why there are occasional cryptic messages appearing every now and again.
Posted: Mon Feb 09, 2009 10:14 am
by Tubal Cain
Am I right in thinking that once this facility is established the photos downloaded to this site will be in a central location, whereas at the moment they are accessed by means of links to Yahoo, Photobucket etc?
Gerald
Posted: Mon Feb 09, 2009 1:16 pm
by BarryT
What a good idea, keep working at it Mike and hope it works out.
Regards,
BarryT
Posted: Mon Feb 09, 2009 2:50 pm
Yes you are right Gerald, it will be located in my front room
But as we are self funding we cannot afford the high tec gear so we are putting things together between the three of us. Once Mike has done all the hard work.
Posted: Mon Feb 09, 2009 3:06 pm
by Bensdexta
Brian wrote:Yes you are right Gerald, it will be located in my front room
Hope you don't switch it off
Ben
Posted: Mon Feb 09, 2009 4:00 pm
by Tubal Cain
This site means a lot to me, I visit it at least once a day. So if necessary I am prepared to make a monetary donation towards improving it and securing its future if necessary.
Gerald.
Posted: Mon Feb 09, 2009 5:54 pm
Thanks for that Gerald but Oscar and I feel that if we accept any monetary donations it puts an increased load on us to ensure that all the information given is correct and there can be no comebacks on the site.
At the moment, we want to keep everything free and informal although we are investigating ways to fund any expansion. None of us want to go down the advertising pop up route though.
Once again many thanks for your offer, it is really appreciated.
Posted: Mon Feb 09, 2009 11:49 pm
by Mike Kuscher
Nice offer Gerald,
A lot of us feel the same way but, it carries associated 'dangers'.
So, everything is being done on the 'cheap'.
Even the intended 'server' was considered 'spare' and I negotiated its' 'donation'.
Ruddy cheek
When this server goes 'live' you will find it is 3.2GHz CPU, 1Gb RAM, 80 Gb Hard Drive ...
Had this running once but found, within 36 hours it had been 'hacked' so, started again.
Currently tring to find out if the present problem is...
(a) suspect 'link' since I installed a wifi network card, instead of hardwired.
(b) possibly port forwarding and firewall needs modifying now that it's wifi networked.
(c) service provider could be applying 'fair usage' restrictions, even though I'm supposed to be 'unlimited usage'.
It's probably (a) and (b) combined but it takes a time to sort out (long hours and much 'away from home' to earn a crust)
Then, of couse, once it's all sorted, I have to get it to Brian and set it up all over again
Trouble is, you see, it works perfectly within my home network. The problems are external reception so it's, "go out, test, come back, adjust, try again
Pity Meanderer is so far away, I have reason to believe he 'knows his stuff'.
The other 'problem' is that, for this sort of thing to work, you usually need a 'static' IP address from your service provider (they constantly change your IP, mine at least once a day, that's how they keep control and earn extra
) and a 'formal' web site. (More expense etc.)
To overcome this, I've registered a 'free' website through dyndns.org (fordsonlad) and installed a piece of software that constantly looks at the IP address the service provider gives then, when they change it, automatically makes the corresponding changes to both dyndns and the ftp server.
Of course, these are more things I can (do) screw up as I make changes
Be patient chaps, it's on it's way...
P.S. Jack (Commander). Also playing with the fact that there are slightly different results if I view with IE, Firefox or Ophra. Obviously, I need to 'stabalize' for all browsers.
Mike
Web site security
Posted: Tue Feb 10, 2009 1:20 am
by Bensdexta
Oscar/Brian/Mike,
How secure is the information held on this website? It would be a tragedy if information was lost or even unavailable for a period of time.
I've experienced such an outage with a car forum and the loss has serious implications for members who depend on such information to maintain their cars/ tractors, etc.
I'm sure you have back-up etc well covered, but it would be comforting to be reassured about this after all the hard work put into this excellent site by so many people.
All the best,
Ben
Posted: Sat Feb 14, 2009 12:48 pm
by Mike Kuscher
OK,
Try another one.
Can you see this ?
OK Gerald and Ben, how about now ?
Posted: Sat Feb 14, 2009 12:56 pm
by Tubal Cain
Mike,
No joy I can only see the address!
Gerald
Posted: Sat Feb 14, 2009 1:13 pm
by Bensdexta
Mike,No joy here either:
"550 path does not exist"
keep going
Ben
