Recovering old batteries
Posted: Thu Jul 01, 2021 11:24 pm
by Billy26F5
A few days ago we suddenly decided to see if we could recover some of the old batteries we have (one could well have been sold in the early nineties!). We started with this one out of our half Super Major, which is quite old, having sat out in the weather for about 12 years and been out of use in that Super Major for quite a time before we got it. It read 0.68V, but after charging for quite a few days (not overnight) it now reads some 12.46V, although we're going to give it a good bit longer and overnight.
The second battery went on when we recovered the beautiful old charger that had been forgotten about for ages (this one is a local one, made at a place only 20 miles away); and this battery would have been used by Billy well before we got here. It read 0.77V before charging. The large white one was Billy's from 2005 to 2010, when we tried to recover it but it didn't really work, we eventually dumped it in the barn dry. It reads aprox. 5V.
The other fairly large one was the brilliant one that our Land-Rover Kenny had until a couple of years ago when it died (it read 5V then, but it now reads 9V). Since then Kenny has needed borrowed batteries, but he's now got a fuel leak again and we need a new seal before we can run him again. The two wee ones (one reads 3V and the other 5V) are for our Renault 4 car and van that also need urgent cover to combat corrosion attacks in the floor.
We have no idea if this will end up being successful, but it seems silly not to try it especially with the shortage we have at the moment of good ones and the large collection of old ones we have in the barn (we've got more than twice the ones mentioned that died at some point!).
Any advice welcome!
Re: Recovering old batteries
Posted: Fri Jul 02, 2021 6:07 pm
by John b
Posted: Fri Jul 02, 2021 6:08 pm
by John b
Never tried this but keen to know if it works!
Posted: Fri Jul 02, 2021 9:29 pm
by Billy26F5
We tried the Epsom salts in the large white battery, but we probably didn't clean it properly because it didn't work. We'll try it again though, as it might work if we clean it properly, but we'll charge them first to see how gone they are to start with.
Posted: Wed Jul 07, 2021 6:06 pm
by Billy26F5
I just connected up the Hurricane starter (pic coming, used the three leads and solenoid from the half Super Major, operating the solenoid manually and not moving the engaging lever) to the two batteries that were charging, the half Super Major one did virtually nothing (I think we need fresh electrolyte in), but the old one survived about seven consecutive start attempts, each lasting about 0.5 seconds and it kept its voltage! I think Billy's long awaited new battery is an old one he used over 25 years ago! All of this after a six day continuous charge.
Posted: Wed Jul 07, 2021 9:53 pm
by Billy26F5
Here's a pic of the arrangement awaiting the next battery (note similarly bad insulation on this starter lead compared to Billy's one).
Posted: Fri Jul 16, 2021 12:10 am
by Billy26F5
Billy26F5 wrote: ↑Wed Jul 07, 2021 6:06 pm
The old battery is on and works 25+ years later! It has been on the charger for much longer than intended, but it survived four starting attempts today (two false ones because the poles are not as clean as they might be), we'll see if it can start Billy again tomorrow.
The half Super Major one's electrolyte has become more competent just from sitting, as I dropped some on a brick (it was coming out of the cell cover) and it reacted quickly, when it had been leaking out while charging and not bothering the bricks beneath it at all. The three car batteries are needing attention (the Kenny one definitely needs a flush, the Renault 4 ones I think need more charging) and I halled out another few that will do Mr. MacGregor and Davie that I haven't got to yet.
Posted: Sat Jul 17, 2021 12:10 am
by Billy26F5
Posted: Sat Jul 17, 2021 6:35 pm
by John b
Hi Sandy, are the rubber injector seals leaking on Billy? I noticed the bits of rag tied round them
Posted: Sat Jul 17, 2021 9:37 pm
by Billy26F5
Yes they are, but not much and only after running. We might do something about it, but it's not alarming, it helps to keep him clean with those rags but not much more.
Posted: Sat Jul 17, 2021 10:19 pm
by John b
This stuff is amazing, i've used it on injector rubbers, water pumps, rusted thermostat housings and even pitted liner seal grooves. I think they sell it on amazon
https://www.google.com/url?sa=t&source= ... s9uLHAdrzi
Posted: Sat Jul 17, 2021 11:14 pm
by Billy26F5
That was the sort of stuff I was thinking of for them, but we need to do it when we're not doing much and it's not too hot (as it is now). Billy has many more leaks but only one is serious (pedal cross shaft on both sides, it just pours out) and we're pretty close to being able to fix it.
Posted: Sat Jul 17, 2021 11:27 pm
by John b
It's not cheap but well worth the money. There's always a few jobs to do to keep these old tractors running but it's well worth th effort
Posted: Thu Jul 22, 2021 10:46 am
by Billy26F5
Billy26F5 wrote: ↑Sat Jul 17, 2021 12:10 am
The battery is performing very well considering its age (25+ years old).
We realised we could date the battery more accurately, here's a pic of the guarantee, although the specific month and year are unknown at the moment. It's still doing fine.
Posted: Wed Aug 18, 2021 1:33 pm
by Billy26F5
Just a quick update.
All of the batteries here
have been on the charger, only the old one that Billy's using now (the oldest one of all) and the Renault 4 one on the left (this one hasn't had the powerful charger on it yet) have been close to doing something on the test with the Hurricane starter.
Additionally, all our other batteries are out, awaiting charging, charging or awaiting more drastic action.
This battery on charge now started at -0.6V! It's never been used, our neighbour had it and was going to dispose of it but I thought we should try it as it's brand new.
The next step will be a good clean and new electrolyte with Epsom salts to see if something will come from this, we'll need distilled water for that, and we're quite short of normal water at the moment, so we won't be doing this for a while yet.
Posted: Fri Oct 06, 2023 12:16 pm
by leeroy
Sandy did you ever get "positive" results here? I was thinking of having a go at this. Turns out the battery I had in Hyacinth has one bad cell that only has .6 volts. The other cells all have 2.1 volts. For what its worth Hyacinth is negative ground with an alternator. This is a group 31 battery.
Also interesting is I stole the battery from our plow truck and have the exact same readings. Hydrometer shows the other 5 cells in both batteries are good, or at 75%.
Posted: Sat Oct 07, 2023 9:00 pm
by Billy26F5
Unfortunately there aren't many updates, the only one that's back in use is the one you've already seen. I haven't been able to measure the cell voltages on our batteries (only the full battery voltage) but I would love to. Try charging just that cell (at just over 2.1V, not at battery voltage as that would be dangerous) and see how that goes. I haven't used the hydrometer much as we're short of fluid for sorting that, whenever I have looked at it I've always had poor readings but that might just be that the hydrometer itself is not quite right. Can't check other batteries easily as they're these newer sealed things. I suggest you look at the electrolyte and if there's any sludge in there you probably want to get that out, but be careful as that's very nasty stuff. Several of ours need that but I can never get round to it.
