It is time to start making it running again. The tractor is rather worn in some parts but ok in other. The front axle has the short drive shaft broken and removed. For this i have a replacing shaft. In Sweden we usually like to have a cabin, good when rain and cold. But it is in the way when working on it (I guess you do not say screwing which would be the direct translation)
The original engine was partly disassembled and had got rain in it. For parts i have a late truck engine with FL-top. I quick noticed that the hole for the primary fuel pump was bigger.
It was easy to disassemble the rest, except the crank, when still on the tractor.
The cogwheels on the camshaft was loose, Brian asked about this in an old thread. Is it a sign of something?
Here both engines are taken apart and next weekend i will try to measure what is good and not.
The block seem ok with some rust on the top flange for the cylinder o-rings, the original crank is rusty and the camshaft seem worn.
The truck engine seems in a good shape but one issue is the one bolt camshaft. The front mount plate does not fit.
Should I try to use the original block with inner parts from the tractor motor? Then i need a new front plate.
Should i use the truck block (and save the original one for the future
![Smile :-)](./images/smilies/icon_smile.gif)
Should i reuse the springs in the FL-top, i understand they are stronger for higher revs, or use springs, valves etc. from a renovating kit?
Should i regrind the truck camshaft to tractor spec?
If the original camshaft is ok things are easier. But still need to think about strong valve springs.
What do you, with your experience, think?
(Edited some errors)
