boughton winch
Posted: Wed Nov 09, 2011 9:59 pm
by woodcutter
this is a boughton winch i have on a major, Can any one tell me any thing about it? how old would it be, what would its rated pull be. It says hdf25 on the side. Ive got the spades which are heavy i thought you could pull them back up with the winch, But once folded up the rope need's to be underneath so it take's two to lift them up
Re: boughton winch
Posted: Wed Nov 09, 2011 11:17 pm
by Bensdexta
Guy with a 6cyl Super Major and 205 Boughton winch at Newbury Show for last two years:
http://www.fordsontractorpages.nl/phpbb ... f=7&t=2531
Called Freddie, phone him on 07836 229949!
Re: boughton winch
Posted: Tue Nov 15, 2011 4:52 pm
by woodcutter
I gave him a ring but i did'nt quite get how he's made the arm, to lift the spades up so if any one knows how it's done. Could you send me a picture of how it connect's to the hydraulic arm
And some measurements
Re: boughton winch
Posted: Tue Nov 15, 2011 6:32 pm
by Bensdexta
Looks like he has a bar with some chain attached to the LH lift arm. Not quite sure how this pulls up the spades. Looks as if the bar may be fixed rigidly at the end of the lift arm? Or does it pivot here? He also has a bar attached across the top of the mudguards - not sure if this is anything to do with raising the spades?
Spades are secured in the up position by the link onto the winch body.
Hope you can work it out!! Otherwise you'll have to go to his next threshing demo!
Re: boughton winch
Posted: Tue Nov 15, 2011 8:51 pm
by woodcutter
Good pictures, Just what i needed thanks for putting them on
Im going to need to make something to pick mine up. that looks a simple way of doing it, I had planned on a complicated linkage set up
which probly would not of worked, or just a hydraulic ram off the tipper pipe. I shall put sum pictures up on what i come up with.
Re: boughton winch
Posted: Wed Nov 23, 2011 8:35 pm
by woodcutter
I made an extension on the lift arm, Like the one in ben's photos and it works really well
The extension piece was an old ih434 draw bar, Just the job
Re: boughton winch
Posted: Wed Nov 23, 2011 8:55 pm
by Bensdexta
Quick work!
How did you attach the extension bar to the lift arm?
Looks like you have chopped off the RH arm?
Glad to hear it lifts the spades OK
Re: boughton winch
Posted: Wed Nov 23, 2011 10:19 pm
by woodcutter
I drilled a hole in the old draw bar and made it a tight fit and welded it to the arm and boxed it in, I kept the original arms as they were a bit good to get butchered but a neighbour gave me some that weren't so, I was going to leave it with no arm on the right but as i had a spare i just cut the end off so it didn't catch on the gear lever of winch.
Re: boughton winch
Posted: Wed Nov 23, 2011 10:42 pm
by Bensdexta
Have you plans to use the winch - for logging perhaps??
Re: boughton winch
Posted: Thu Nov 24, 2011 12:12 am
by woodcutter
Yeah this weekend
I sell firewood and i have some large trees that are down on a steep bank which need winching up and a friend of mine has an old bulldozer stuck so iv'e got to rescue that if the ground ever dries up.
Re: boughton winch
Posted: Mon Nov 28, 2011 12:17 am
by woodcutter
Re: boughton winch
Posted: Mon Nov 28, 2011 1:30 am
by Bensdexta
Good work! That lot should keep you busy for a while! What sort of splitter do you use?
A vid would be great if you can manage it sometime ?
BTW do you know why Freddie has that bar across the tops of his mudguards - anything to do with the winch do you think??
Is there any risk of whiplash if the cable should break? I guess you would get some warning as strands started to part?
Re: boughton winch
Posted: Mon Nov 28, 2011 6:46 pm
by woodcutter
I use a home made log splitter
http://www.youtube.com/watch?v=4cN7su9tISo
my brother made a video of us winching yesterday but quality was pretty low
I'm not sure what that frame is for on the back of freds major, is it just to firm up the rear mudguards maybe
Re: boughton winch
Posted: Thu Dec 15, 2011 10:31 pm
by Roadless63
I spotted this boughton winch at one of the cambridge sales a few years back and thought the ram installation was a good idea. I have a HDF/2P (if I remember correctly) which has an extra low gear for timber work. Its sat on the back of a 1964 roadless but the gearbox needs some tlc amongst other things so it is currently in hibernation.
Re: boughton winch
Posted: Fri Dec 16, 2011 12:28 am
by Bensdexta
Roadless63 wrote:I spotted this boughton winch at one of the cambridge sales a few years back and thought the ram installation was a good idea. I have a HDF/2P (if I remember correctly) which has an extra low gear for timber work. Its sat on the back of a 1964 roadless but the gearbox needs some tlc amongst other things so it is currently in hibernation.
What does the ram do? Is it for raising the spades?
Re: boughton winch
Posted: Fri Dec 16, 2011 9:28 pm
by Roadless63
Yes its a single acting ram to raise spades/anchors. Should be fully extended and rod end attached to the clevis on the spades which is visible in picture. Gravity would retract ram for lowering and when it digs in it needs to be free to drop onto the stops hence a double acting cylinder would not be a lot of good.
Re: boughton winch
Posted: Sat Dec 17, 2011 10:13 pm
by woodcutter
I was going to do that with a ram, But i didn't have any suitable rams lying around. And by using the lift arm seemed a lot less fab work, and cheap
do you remember how much that winch sold for.
Re: boughton winch
Posted: Sat Mar 24, 2012 10:38 pm
by woodcutter
Re: Boughton winch
Posted: Sat Mar 24, 2012 11:26 pm
by Bensdexta
Glad to see she's working well.
Those are massive rearwheels you got.
Re: Boughton winch
Posted: Sat Mar 24, 2012 11:30 pm
by Bensdexta
Posted in error!
