Hi all
Now i`m a proud new owner of a County Super Six.So now i have a 52 e1adkn tvo Major(1240819) a 61 Super Major(1617909)and a Super Six(618155???)
The Tractor is Complet
except the P.S.-Pump is missing.I have a spare one with Bracket from a Super Major.Is this the right Pump?With the Tractor came a Pump from 5000 or so.
Can i use the Pump/Bracket from the Super Major?
And what Oil comes in Driveunits for the Frontaxle?
The Engine is free but needs new Liners (Rust!!!)not a big problem for me i`m a Car mechanic.
And where can i find the serialnumber?i found a number on the Engine
Under Zyl.1 Injc. 618155.Is this the serialnumber?
mbg Jan Westerfeld
County Super Six
Re: County Super Six
Welcome aboard Jan.
My County’s use the Major power steering pump. I assuming yours is the Fordson Major based Super Six, so the bracket should bolt up on the front of the head same as the Majors.
The front gearboxes us normal gear oil, I’ll have to look in the manual to see if they recommend a 80W90.
It sounds like you have the correct Ser No for the engine. If you go back to the Home page look under the listing for serial numbers, this will also help you date it with the casting numbers. The County Serial number and tag should be on the front of the left running board.
And don’t forget to POST SOME PICTURES, including the Majors!
Pat
Pat
Yes she is based on Super Major.I will take a closer lock on the numbers this weekend,and try to make Photos.Photos from the Tvo Major are still in this bord
(made during restauration).Take a look at my older Postings(E1ADKN in Germany)
Photos from the Super isn`t a problem,there are many in my Computer,plus some
Photos from my friend Dirk who ownes a Power Major.I will make a new Album,and upload them.
mbg Jan Westerfeld
I wish my English is as good as all the Fordsons!!!!
mbg Jan Westerfeld
