BearCreek Majors wrote:
I'm thinking the wheels will turn farther thus having a shorter turning radius, not to mention wider is more stable,
Pat
Correct me if I'm wrong here Pat, but we are talking about a front axle which pivots on a pin mounted along the front to rear centreline of the tractor, then the width of the front axle will have no bearing on the stability of a tractor.
The width of the rear wheels will have a bearing on the stability.
If you jack up the say, left rear wheel, the right rear wheel will stay on the ground. The more you jack it up the more the left wheel comes off the ground, but the right wheel stays on the ground. The 2 front wheels stay on the ground, as the axle pivots on the centre bush.
Once you have used up all the front axle pivot travel (when the tombstone contacts the front axle) then the width of the front axle will have a bearing on stability.
If you're on the side of a hill, and 1 of your rear wheels is 2 foot off the ground before the front axle gives you more stability, then I think that we are pushing our luck with safety.
I am following this thread closely, as I once was going to build my own 4WD major. Have since decided that it is better to have 2 tractors. 1 which is 2WD for 90% of your work, and 1 which is 4WD for the other 10% of the work.
As I said, correct me if I'm wrong. We are never too old to learn.
Kiwi Kev
