Dexta Roadless parts
Posted: Wed Mar 09, 2016 1:32 pm
by Broadspeed
Does anyone have pictures or maybe even some measurements of roadless power take off piece between gearbox and rear axle?
All help is highly appreciated
Re: Dexta Roadless parts
Posted: Sun Mar 13, 2016 6:26 pm
I am pretty certain I have some pictures in my files somewhere so i will check them out and upload them. You do realise you are looking for rocking horse poo and hens teeth?
Be careful if you do find one as for some reason the Roadless Dexta slice is prone to cracking and breaking.
Posted: Sun Mar 13, 2016 9:20 pm
by Broadspeed
Yes I know that in this case any information to get will be very hard
My intention is to make 4wd Dexta, one way or another
Everything is clear, except the power takeoff to front axle. May be that it is easiest to make it with chain, as all grip traction has done
If You have pictures, they are more than welcome
Posted: Thu Mar 17, 2016 10:11 am
Posted: Sat Apr 02, 2016 10:52 pm
by redgiant
Broadspeed wrote:Yes I know that in this case any information to get will be very hard
Broadspeed if you do end up making a 4wd Dexta do make sure to put up a thread here going into great detail - so I can copy you
As for the chain idea, I've heard it's a bit of a weak link in the design (pardon the pun)
I'm guessing Roadless had a large idler gear and a smaller one connected to the prop shaft??
Posted: Fri Apr 08, 2016 12:28 pm
by Broadspeed
Yes I also think that the chain version won't be very strong. That's why I asked for pictures from a pto piece, which is separated from tractor. But I think that nobody has pictures of it
Google gives only pictures where this piece is assemblen in tractor..
Posted: Wed May 11, 2016 6:13 pm
by Pascal
Posted: Wed May 11, 2016 7:45 pm
by redgiant
If only I had the money!! I dont suppose you have any more pictures/ info about the transfer box? And was the front casting the original or was a stronger version fitted?
Posted: Mon May 16, 2016 11:24 am
by county654
Broadspeed wrote:Yes I also think that the chain version won't be very strong. ..
Hallo,
If you are afraid, a single chain won´t be strong enough, look for "duplex chain" or even "triplex chain"
https://www.google.de/search?q=duplex+c ... oQ_AUIBigB
We used to have a single row cornchopper in the 80th, it was powerd with about 90 hp and the duplex chain lasted forever.
A 35 hp Dexta has no chance to ruin such chains if they are proper size.
Posted: Mon May 23, 2016 5:11 pm
by county654
A tractordealer in the neighbourhood is offering a Dexta Major 4x4 at the moment.
I have never seen one in real, so I went there this morning.
Price would be 8.000 € .
I have to many unfinished projekts, otherwise I might be interesteed in buying it.
Posted: Mon Jun 13, 2016 6:19 pm
by Broadspeed
Use You are right, maybe Dexta with her 32 might horsepower can't break a duplex chain
Just found 7,50-20 front rims and tyres for my project.
Posted: Mon Jun 13, 2016 6:49 pm
by redgiant
Broadspeed would you please post some updates/pictures of your build? I for one would be VERY interested in what you're doing.
Posted: Tue Jun 14, 2016 5:02 am
by Broadspeed
Yes I will post as soon there is some progress
Now I have only picked up parts for this project. Have been busy with few other projects, and with this Dexta 4wd I don't have to rush
Posted: Fri Jun 17, 2016 1:39 pm
by redgiant
Posted: Fri Aug 05, 2016 9:06 am
Picture come from Wales sent in by "Dinas" who used to post on here. The axle is a Land Rover one done by a company in Wales but it is not a good job from what I have heard. Bit cheap and cheerful. It has been reported on in the tractor mags.
