County 1164 sump removal
gme75
Post by gme75 »
What are the quickest and easiest ways (if any!!) of dropping the sump and removing to replace oil pump on County 1164?.
Do you drop the axle, or can you undo axle and lift tractor above axle to gain access to sump?.
gme75
