Its a 1962 super major bought in a running but in rough condition,
The engine is a Deutz V12 f12l413 removed from a aircraft tug from Manchester airport.
this is gonna take a while with the slow internet and photobucket ad explosions
im in macclesfield cheshire, your right the closer i get to the end the further away the end getsoehrick wrote:You will need to find them if you hope to claim it as a 'nuts & bolts restoration job'![]()
Decent solid place to work in and a bigger 'hell hole' than many try to manage with.
the last 10% of the job takes 90% of the time is a reasonable rule of thumb to use in my experience.
Where are you located - in the Manchester region based on the engine source and stonework ??
