J17 crawler
J17 crawler
Hi everyone here is a roadless crawler i have just bought
any information will be very helpful
thank you
tom
thank you
tom
Re: J17 crawler
Roadless,
Congratiolations. I hope you have the engine to
Re: J17 crawler
Could you post some more photos please as I dont think I have seen many if any of these before, they are much rarer than the County crawlers
Matt
Matt
1945 Ransomes MG2, 1950 P6 E27N, 1963 NP Super Major
Re: J17 crawler
hello here some pictures/ info
Re: J17 crawler
Thanks for the pictures
here are some more pictures of my crawler when me and my brother have started taking it to pieces
it is converted from a 1956 tractor and i have found that the left hand rear wheel studs are left hand thread, i am sure this is not standard for the tractor
Re: J17 crawler
hi hereare some more pictures of my progress
Here is the crawler with the transmission removed and the engine donor tractor
here is the steering clutch removed
Re: J17 crawler
here is the transmission of the breaker tractor in pieces
Re: J17 crawler
Hi here are some more photos of my progress
here are the rusty gears removed from the crawler gearbox
here is the crown wheel bolted back on to the carrier
Re: J17 crawler
You are doing a great job.
Re: J17 crawler
I want one for myself
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
1964 County Super-4
1967 County 654
Re: J17 crawler
Hi cheers for the replies
I have some more pictures sorry i havent managed to keep them all in order
here is a home made spanner used to remove some large nuts whick hold the clutch drums
and here is the spanner in action with help from a sledge hammer
removing the bearings from the pinion reduction gears
Re: J17 crawler
hi here are some more pictures of my progress
here is an original ford special tool back in use the major half shaft bearing puller
Here are the castings sand blasted and sprayed with the first coat of primer
Re: J17 crawler
i mmust say i like the homemade spanner
Re: J17 crawler
hi cheers about the spanner it still took a bit of persuasion
here is the crown wheel and pinion back in and all shimed up
Heating the bearing up in the chip fryer
The bearing fitted on the half shaft
Setting up the preload on the half shaft bearings
Re: J17 crawler
here are the steering brake bands i sent off to be re lined
Re: J17 crawler
I had Not seen a J17 for many years! That one is really early because they changed to multi-plate clutches in the mid 1950's before County.
Be very careful with the tracks, they are like a massive spring when you split them as you may have found out. They are very hard to get back together without the compression tool, Do not stand directly behind or in front of them.
Re: J17 crawler
Hi the tracks did go with a bit of a spring
here are the rear axle gears all back in place
the gearbox was all appart and inspected it all looked in good condition untill i noticed a crack in this caseing
I have never heard of this happening before
Last edited by roadless J17 on Mon Jun 04, 2012 10:42 pm, edited 4 times in total.
Re: J17 crawler
Cracks were a very common occurance especially if a transmission hand brake was fitted. Using the brake to stop or driving around with it just on were the usual cause. New or s/h housing could be the order of the day.
Re: J17 crawler
hi i have another caseing
and the crawler does not have a transmission brake
Re: J17 crawler
Here are the brake and clutch pedal pivots
i drilled the weld off from the inside and pressed in some new bar and re welded it
Re: J17 crawler
here are the pedal pivot brackets sand blasted and painted
the holes in the swinging drawbar were badly worn so i drilled them out and turned inserts and welded them in
Re: J17 crawler
Have you got an engine sorted for this now?
Re: J17 crawler
Hi here is what i have for an engine
i need a early sump with the removable aluminium strainer cover
Here is the seat i have made
Re: J17 crawler
Here are some more photos
here are the new footplates 1/4 plate with 7/8 spacers welded on
Re: J17 crawler
Here are some more photos of some crawler progress
the tops of the wings being folded
and the sides with the fitted footplates
