Any ideas of what to look for? I've had the inspection cover off and squirted diesel around in there, which has freed up 1x pumping element, but still 1x not pumping.
Although the injector pump has been off the engine for a time, it was sealed with caps , where possible. (the injector pipes are only removed while taking the photo)
The excess fuel button also wont stay in when pushed. Should there be any clips/springs that hold it in until the engine starts.
Also, can anyone confirm the type of Simms pump this is.
Kiwi Kev
