Thanks for the tip ben - this is what I have come up with to lock the crank - I found a long UNF bolt to fit in the flywheel flange bolt holes and this rests on the engine stand. I have a long bolt in the alignment hole in the flange and have packed them both out so they don't damage the engine stand and both take a share of the load.Bensdexta wrote: Also you will need to lock the crankshaft somehow to prevent it turning whilst you undo the pulley, unless you have an impact wrench (and toughened box spanner). I made a long spanner which I bolted onto the pulley bolt holes. This worked but I later discovered my pulley had a hairline crack (spotted by an eagle eyed reader after I posted a photo on here!) by the key way. I can't help wondering if the spanner attached to the pulley was the cause. Better to lock the crankshaft itself rather than the pulley, so maybe bolt your spanner on using the flywheel holes.
The spanner was a problem, my mate had a 1 5/8 AF socket but its not quite deep enough as the starting handle ratchet/dog protrudes, however he did have a 1" whitworth cranked ring spanner. The correct size across the flats is 41.28mm or 1.625" while the 1" BSW is 42.42mm or 1.67", so not a lot in it. Here's a shot of the spanner on the nut and the socket that is not quite deep enough hanging off of the water pump studs. I can't see why they have a starting handle dog on the nut in the first place, with the compression of a diesel engine and needing to crank it upwards of 100rpm then its nigh on impossible to start with a handle - unless you know differently
The lugs for the fan bolt holes get in the way of the spanner, probably fine with the correct 1 5/8" AF spanner but with the slightly larger 1" whitworth then its important that the lugs are closer to the spanner in a clockwise direction, not like in the following picture as pulling on the spanner tends to push it off the nut and could damage the pulley.
I gave it a quick go on my own, I put a strap under the engine hanging off the hoist and couldn't budge it with downward pressure and lifted up the engine and stand with upward pressure and the strap removed. The ring on the spanner stops the usual farmers method of slipping a scaffold bar over it. So I have enlisted the help of another neighbour who has muscles on his muscles and is used to stubborn nuts on big machinary while I have the centre of the nut full of WD40 type stuff. Its safer to have 2 when giving a stubborn nut some welly
