Morning people,
I have some ID numbers from two tractors, one of which I'm looking to buy. Can anyone help with dating, wether the codes tally, any information would be appreciated.
Here are the numbers.
Tractor 1.
Serial No ( under injector) 08C782555
Casting codes..(clutch linkage) N14X
Hydrolics (under seat) N14X
Front axle 2N5
Engine block, has no number, but has a raised ford emblem.
Reg 443DBD.
This tractor has round wings in blue.
Tractor 2
Serial No (under injector) S362707
Serial No( on fire wall) 1404018)
Casting codes (clutch linkage) L24Z
Hydrolics (under seat) H3V
Front axle 13L6
Engine block, has no number, but has en fo cast into block, also has this mark on cross member,by bottom left of radiator looking from engine.
Thanks. Pip.
Serial/ID Numbers
Re: Serial/ID Numbers
Tractor Number 1. Fordson Major ASP.
Engine. January 1963.
Clutch Housing: December 14th 1955
Hydraulics. December 14th 1955
Front Axle November 2nd 1955.
Tractor Number 2. Fordson Major ASP.
Engine. replaced with Industrial unit. No Date available.
Serial Number. October 1956
Clutch Housing. September 24th 1956
Hydraulics. June 3rd 1954
Front Axle. September 13th 1956
Jimcdbts
Serial no S362707 is from Jan 1964
Jim
Jim
