I'm Maarten from Holland.
We are rebuilding a fordson super major.
Now we have a problem with te gauges.
Our fordson is one with the 2 gauges near the steering wheel.
The problem is something with the oil pressure control light, and something with the loading control light.
Now, the oil pressure switch wire is connected with ground. Positive.
For example:
The holder of the oil control light has 2 wires. One from the switch, in the middle of the holder.
On the outside of the holder is another wire, also connected with the outside of the light holder from the loading control light.
So i think that the outside from the oil pressure holder must be negatave: the light will turn on.
When the oil pressure switch disconnect the positive switch, the light will turn off.
When we fit the gauges and the housing on the tractor, then the housing will be positive ( earth).
But what i thought: the outside of the lamp holder has to be negative...
The lamp holder, in the gauge, on the housing, makes metal on metal contact.
When that is negative, and the earth is positive....smoke and more horrible stuff....
If anything is not clear, juist ask and i will answer in my best english
Must i isolate the lampholder? I dont think so..?
Anybody an idea?
by the way, i think that we need this wiring diagram:
