Today I have been mostly.......
neilarmo
Post by neilarmo »
adding to the fleet
is that any better
chriss
Re: Today I have been mostly.......
Post by chriss »
am i the only one who can't see the photos?
Me too Chriss.
Niel, could it be that your pictures are behind a login?
Kiwi Kev
Post by Kiwi Kev »
I can see them, both now, and this morning when I looked.
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Looks like you need to be a member of the forum to see the pictures as they are password protected.
chriss
Post by chriss »
logged in but still can't see them
Sorry Chriss, you need to be a member of Neil's forum to see the pictures not this one.
neilarmo
Post by neilarmo »
edited, thanks for the heads up,
and Kiwi Kev is a member of the other forum too ;)
Now I really need to clear out 'the stores' so I can get it under cover.
What's an unknown condition, but turns, 590E worth with injector pump and manifolds?
chriss
Post by chriss »
neilarmo wrote:adding to the fleet
is that any better
much :D
super6954
Post by super6954 »
neilarmo wrote:edited, thanks for the heads up,
Nice looking tractor on the whole :D but got some odd parts on and a some missing :wink:
So for us that are missing something here whats the other "secret society" forum you guys are members of :lol: .
The 590 or 6D as most know it, are better if complete known runners, they had a bad reputation for wearing the cranks the same as Major motors. if you start it and find low or no oil pressure when warm. You got to either hope the crank can be re ground, or find a good one to replace it if worn past 30 thou re grind.
The oil pump is bigger than a standard major motor I believe as well. Don't know of anybody doing new cranks or oil pumps for them :cry: . I would be at scrap price plus a bit. good ones seem to be making around 300- 500 quid plus, on Flea bay at the moment, allowing for people that don't know when to quit bidding :wink: .
I Got an early one here in Canada and can't find a crank to fix it at the moment. you may have a better chance in the U.K finding good used cranks if needed :wink: . see plenty of parts to fit them around for almost everything else. some of it is the same as the major, only more of them used like sleeves, pistons rings. gasket sets are available also from a few guys
They can also suffer from the same block sealing ring problems as the major motor can with corroded seal grooves/rotted liner bottoms, or dried out leaking liner seals, really a dry stored non running motor is a huge gamble full stop when i think about it :!: . you won't know it might be trouble until you own it and try running it if buying one :eyes: .
sorry it's not really a positive outlook on the motor but junk is out there and these things are getting way past legal smoking age and very close to getting an early retirement pension :lol:
neilarmo
Post by neilarmo »
I have a top link bracket in the shed so that's sorted.
Tractor had a loader on from new so had the silencer through the bonnet and the smaller bonnet handles so loader didn't catch. Seems to make sense.
scoobyjim
Post by scoobyjim »
Is it the proper new performance top link bracket?
neilarmo
Post by neilarmo »
scoobyjim wrote:Is it the proper new performance top link bracket?
unfortunately not, but I'm looking......
Post by Dandy Dave »
Nice find. 8) Dandy Dave!
scoobyjim
Post by scoobyjim »
I need one too. May have to look at borrowing one off someone and getting some cast.
Jimcdbts
Post by Jimcdbts »
Lo and behold a tractor with a ploughing lamp fitted
neilarmo
Post by neilarmo »
Jimcdbts wrote:Lo and behold a tractor with a ploughing lamp fitted
shhh, I think it's just single bulb.
the one on the other super is just a 1970's afterthought
AdrianNPMajor
Post by AdrianNPMajor »
The photo appears to show a Super hydraulic lid, and not a NP Super lid. To be sure, does the lid have an aluminium knob near the pressure relief valve?
Best
Adrian :thumbs:
