Were all Major PTO covers the same, I have a E1A, Super and NP super and they all seem to take the same 3 bolt cover, but I have a cover in the shed with a pair of holes on each side. 99% sure it's a Major.
Different PTO covers?
Re: Different PTO covers?
as far as I know from my 5000 tractor here in Canada, and what I have seen in wrecking yards also here. The last blue grey supers had the pto guard bolted on with 4 bolts( 2 each side). The guard is the same shape as all the other majors. But the mounting is 2 angled brackets bolted to the sides of the pto shaft casting using those 4 bolts. then smaller bolts like 5/16th size to hold the guard to the 2 mounting brackets.
my guard is not fitted and sits in the shed someplace
, If I knew where I'd get a picture for you. I don't use it on the mower tractor as it's a very original guard and don't want it wrecked, if the mower ever got lifted to high when the neighbor borrows the tractor
That will be the chap.
Many thanks.
Many thanks.
