Cylinder head
Cylinder head
Best tool for removing the cylinder head it's solid it won't budge cheers Darryl
Re: Cylinder head
I've never had any problems removing any of them, are you sure that you have removed all 17 bolts.
Don't just leave it in the shed, Fordson's are made to work, so take it out and work it....!
Re: Cylinder head
They can be tight sometimes but check the bolts as Anthony says. Also remove all the injectors, they stick through the bottom of the head and are easily broken if you catch them on the sleeves or put the head face down on the bench.
Been there, done that, bought the new nozzles
