How Many Quarts/Liters of Oil in Model F Engine
560Dennis
Post by 560Dennis »
Could some tell me how much oil and the weight of oil to use in the Model F engine ? thanks
fordsonf25
Re: How Many Quarts/Liters of Oil in Model F Engine
Post by fordsonf25 »
I think around 10.2 litres.
It was a fair amount that came out.
Not sure on weight. A heavy oil is recommended.
My 1925 Fordson Blog http://www.fordsons.co.uk
SkidRoe
Location: Tetenhall Wood, UK (was Thorndale, Ontario, Canada)
Post by SkidRoe »
10 litres sounds a little on the low side. 15 is closer to what I remember. I buy oil by the 20 litre pail, and it takes nearly a whole pail.
As far as grade goes, I run straight 30 weight. Our splash-lubed tractors do not get used in the winter (temps below 0C/32F). The peak temps that we see are low 30's Celcius.
Hope this helps - SR
Fordsons: 22 F, 36 N, 50 E27N, 60 FPM Past: 60 Dexta, 61 SM
Fords: 78 6700 Turbo, 81 TW30, 89 4610 4x4 w/ Frey ldr, 96 7740 SLE 4x4 Past: 72 4000 w/ Allied 660 ldr, 75 5200, 76 9600
Others: MH 30 & 44, Oliver Super 55, Bobcat 440b & 773
fordsonf25
Manual says 2 1/4 gallons so I only went by that. Mine is yet to receive any oil but at least 10 litres came out.
To be honest I would use the pet cocks to level the oil when I come to doing it.
560Dennis
Post by 560Dennis »
Again , many thanks for the advice .
