Jamie,
What exactly did you do - cut a piece out of one side and weld a piece of sheet on the outside to give a fraction more clearance? Or did you split it and open it out to a bigger diameter? Or maybe both!?
Was your original one missing, or completely beyond hope?
I'm going to repair mine.
My 1960 project
Re: My 1960 project
Re: My 1960 project
Wow.... a car quality paint job... Geez louise!
Wonderful!
Blacken up the tyres get them to match the beauty of the tractor...
Gosh, I would never believed a tractor that could be so slick and 'wet' looking...
Congrats!
Wonderful!
Congrats!
Re: My 1960 project
Hi Ben,Bensdexta wrote:Jamie,
The problem was the clearance on the left side which, as you know, is offset.
I had enough clearance top, bottom, and on the right, so it was a little frustrating
The first thing was the flat area "A" was not wide enough, (the original was just over 1" at this point, not 3/4"), so I cut this area out first.
Next, the offset side of the shroud needed widening to allow the fan to rotate, so I cut Area "B" to the flange (utilising the flange as a hinge) at the top and bottom to allow me to work with it. Then with heat in difficult places, I beat out area "B" into a wider profile.
That left me with a gap to fill - area "C".
I decided to cut some sheet to fill both areas "C" & "A" combined using a cardboard template, and then gas welded it in.
I will flatten the welded joint with a flap wheel and then gently beat the joint down to shape, prep and then paint.
The problem with my old one is that the lower left corner (which is a complicated shape) is completely missing and someone has just bent some tin around it.
I will maybe have a go when I have more time.
Regards, Jamie.
Last edited by justjamiefarming on Sun Jul 22, 2012 7:40 am, edited 1 time in total.
It was like that when I found it.... & I wish I had left it alone!
Re: My 1960 project
Thanks for your kind words, and a tin of tyre black has just been added to the shopping listMyDexta wrote:Wow.... a car quality paint job... Geez louise!
Wonderful!
Congrats!
Regards, Jamie.
Re: My 1960 project
Finally got the pesky fan shroud finished off, prepped and painted.
Just thought I would share a couple of pics to finish this part of the story.
Next job is to fit the nose cowl, then fill the tractor with oils & water and go for a start-up!
Best regards, Jamie.
Re: My 1960 project
Congratulation,s for your good work on your "bluegirl" Jamie, - from Norway too.
Re: My 1960 project
That's too bad about the fan shroud. A lot of wasted time and money.
Glad you were able to overcome the problem. I would have been really dissappointed when it happened the second time.
Chris
