Great engine to work on, and all the parts are available.
Have fun!
Best
Adrian
DOS. Have not heard that term since the 1980's. Green Screen IBM PC 360's. I can see where it will work well with machining parts. Dandy Dave!oehrick wrote:You're not wrong there Pavel![]()
I can see 'em tonight (and hear the voices !)
I've only recently started using Mozilla as a browser and still have Internet Explorer installed so have been keeping an eye out for any odd actions or conflicts, you know what Micro$oft is like for taking libertieswrote off a drive unit on the 3 axis cnc mill/router/engraver I built from scrap and then discovered that Windows will change port addresses on the fly even when the address is forced by the software, thats why it ran past 2 axis limit switches and into a mechanical stall. I fixed 'em, off came Windows and it runs fine under DOS - they folks in 'merica probably think nobody uses BASIC for control programs these days, ahem well perhaps they don't but I do
Go carefully
No kidding! Are cam bearings even available? I don't think I have ever seen them listed by a supplier.AdrianNPMajor wrote:Here's where the luck factor kicks in. Let's hope that oil emulsion hasn't corroded the crank and the cam and its bearings.
Great photos. Looking forward to seeing more as you get deeper into the engine.
Good luck.
Best
Adrian
