Super Major Injection Pump oil level
williamFSM
Re: Super Major Injection Pump oil level
Well, the bolts finally came in, I disassembled it, the head bolts were loose, ck'd the cylinder protrusion, it was perfect. The new gasket is not copper, but compound. I still retorqued it though! Upon disassembly, the manifold gaskets stuck and ripped, so that was a delay. #1 is a little weak, so I've pulled the injector and am going to attempt a rebuild. If successful, I may do the others also. If it doesn't help, I guess I'm pulling the pump. I had high hopes to be digging out my pond by now.
williamFSM
Ok, tractor is back to functioning level, but I still have no first gear. Where can I get some shift forks?
