My 4ft Slewtic is ideal for a Dexta, feels safe on the slopes and gets right in the corners of the fields, especially when I stand on the brake to turn in own length. It has chains fitted, a must for the rough stuff, I have blades also. Not many toppers can take either chains or blades and it seems pretty robust. I've not been brave enough yet to fit the blades, perhaps when the fields are in better shape. In fact the chains do an OK cutting grass job, although they tend to tear rather than cut the grass - giving split ends
A topper is a brilliant piece of kit,if there's one implement for grassland improvement got to be a topper. Topping just once a year does wonders for the grass, pretty well knocking out the weeds, bracken, rushes, most of the thistles (creepers are more of a problem) and poorer grasses.
Ploughing will be the next stage in the improvement process!
