Do you have to split?
roromac
Post by roromac »
In order to do rings/big end bearings does anyone know if it is necessary to split the tractor or can the sump be removed safely. I fear the sump may be structural
Rob
Tubal Cain
Site Expert Team
Site Expert Team
Post by Tubal Cain »
You will have to split the tractor.
Gerald
If you are going to do mains and big ends it is shortsighted not to have the crank re-ground too. If you need one you need the other on these engines.
This would mean complete engine removal which is the easiest way.
roromac
Post by roromac »
That's what I feared I just didn't want to do a complete rebuild, just what was possible without splitting.
TKU
Rob
