Calling all auto electric-ians, I have decided to keep my wiring 'original' except that I will fit an alternator. The diagram below shows how I think the standard wiring needs to be modified for the alternator; main changes indicated in red, are swapping to -ve earth, and omitting the separate voltage regulator (control box) under the Control Panel. A standard harness can be used, just leave the 4 control box wires (DEAF) unconnected (or removed completely).
Any comments appreciated
I've also shown a 30A circuit breaker in the yellow feed wire from the battery at the starter solenoid post, to the control panel (light switch). An auto-resetting breaker has been recommended elsewhere on this site. Any suggestions on type and trip current appreciated.
One final question, is fitting an isolation switch to the battery terminal a good idea?
Many thanks for your help,
Ben
