Lower Link Mounting Pin
Lastnight I removed the rear linkage to find that the castle nut on one of the lower link mounting pins had been welded on. Once the weld had been removed and the nut split it became apparent the thread had been totally stripped, hence the weld.
I realise that to change this means removing the trumpet housing but wonderd if anyone had experience or recommendations around recutting the thread on the pin with a die set and using a suitable replacement Castle Nut?
Ross,
I don't know how much it costs in England, here they are really expensive here, about $120.00. I bought one for a M)((&y F_(*^**n for $25.00. The bevel that goes in the trumpet housing is bigger or smaller than the Dexta I don't remember, I took it to a friend of mine that has a machine shop and he made me one out the two. It's been a few years and it's showing no signs of trouble yet.
See ya
Mark
Mark
I had the same problem, luckily I managed to free the nut with the angle grinder. The threads were damaged but not stripped, I hadn't got a die set so I used a small file and carefully cleaned the threads up where the weld had been until I could get a new nut on. It was a little bit tight but went on OK.Lastnight I removed the rear linkage to find that the castle nut on one of the lower link mounting pins had been welded on
As your threads are stripped it is a slightly different situaltion, if you recut the thread smaller will it be man enough for the task? The lower link arm mounting pins are available at only £12.00 (Agriline), however it is the hassle of fitting them!
Chris
Brailes, UK
"Dexta's rule the World!"
Brailes, UK
Ross,
You will have to take the axle out first, then the backing plate of the brake, get it out of the way, then take all the nuts off of the trumpet housing except the top one. Be sure you have some help unless you're a young man and have a strong back because it is heavy. When your ready take off the top nut pull it back and lower it to the ground or work bench, now you can take the nut off the lower link pin and replace it. You will need a new gasket or you can make one, your choice. They are not expensive and you can still get them from you CNH dealer.
See ya
Mark
Mark
You don't have to take the axle out. It will all come out as one piece. This reduces the time to do the job and if you don't have to do the axle seal its extra work.
You do need two people or a crane though.
If you can also find a long bolt and cut the head off, to act as a guide bolt it helps. Otherwise a piece of bar to fit in a couple of the holes to help you slide the axle into position.
The pins are available from Agriline and come complete. They have a reverse taper to them hence the reason you have to remove the trumpet to push in the old one and fit the new one from inside out.
If you look at the Dexta Service Manual in section 7 on page 2 there is a clear illustration of the pin assembly. It's down on my 'One day I'll have to get round to doing it' list!
New pin arrived yesterday and I've just been down the the lock-up, remove the axle trumpet housing as a whole unit, removed old pin and fitted the new one. Then bolted the trumpet housing assembly back up. A nice easy half hour job.
Only problem now is I need a new Castle nut. Anyone know what size it is?
Re: Lower Link Mounting Pin
I had a loose lower link pin on my dexta, which meant that oil from the backend was weeping out. Whilst I had the PTO shaft out to replace the leaking PTO seal, I looked in the backend and could see the nut from the link arm pin, so I was able to tighten it up without taking the axle trumpet off. Can you replace the pin this way?
