Please don't faint but----
What does anyone know about a ---------- Kubota--------?
I have been offered one very cheaply but it has water in the sump and fills very quickly. I am told it is a common fault with these tractors.
If it is worth a look at I may sell the Petrol Dexta :shock: !!!!! (Only joking). :twisted:
The Swanndri Guy
Re Kubota
Post by The Swanndri Guy »
Brian, normally Kubota's are quite good tractors, a bit like Toyota cars,effective, get the job done, but not exactly inspirational.Only major problem I can recall that we had here was the little 6 cylinder engines had a tendency to malfunction.(Kubota's over here are imported by the same company that imports CNH tractors, C.B. Norwood, so its not uncommon for a New Holland dealer to sell Kubota's as well, on the same site.)Cheers TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Dunggatherer
Post by Dunggatherer »
If you decide to take a look,watch carefully,because if you need to buy spareparts,it will cost you deerly.
A friend of mine owned one,and it needed a cylinderhead.
Without valves and such the price was...brace yourself...
900 euros plus tax.
So he offered it very cheaply...
Post by Dandy Dave »
I've worked on a few over here and they seem to be a very reliable tractor. The ones that I have worked on have been medium and small tractors. I have never had to do an engine in one. Mostly just servicing them for the local organic farmers. I did put a clutch in a medium size one once with a loader. And a hydraulic pump on an old compact as it was leaking in to the engine oil. With water in the engine I would be weary. You never know if they could have put to much ether in it at one time. Dandy Dave!
wee blue tractor fan
brian buys a kubota ?
Post by wee blue tractor fan »
brian you could be lucky my friend bought a kubota from the scrappys with a sump full of water and when he stripped the engine he found a popped core plug on the cylinder head between the water jacket and oil gallery and sorted it for the price of a core plug and a cylinder head gasket
That is the information I was looking for. It fills up very quickly but runs OK. Will keep you informed.
