seals and bearings
Is this usefull
Poll ended at Wed Jun 02, 2010 3:50 pm
Ja
12
100%
No
0
No votes
Don't mind
0
No votes
Total votes: 12
seals and bearings
I have the idea of making a list of measurements from seals and bearings from the whole range of Fordsons tractors.
What do you think of the idea?
I would need inner and outer diameter and thickness in mm or inches. Type or material of seal (single or double lipped) or bearing, Model and year of the tractor and Fordson part number and place of the seal or bearing. Also supplier could be important.
Planning to make it a database and put the result on the site.
Foxen
Post by Foxen »
I can begin with the seals I've "stumbled" upon so far...
Pedal cross-shaft seal (Rear axle housing behind the pedals)
O.D: 44.45mm = 1 3/4"
I.D: 28.57mm = 1 1/8"
Thickness: 11.11mm = 7/16"
Momentum number
ID OD T Mtr Typ Best-Nr
28.57 44.45 7.93 NBR BA 5005-4353
Super Major Brake shaft seal (Behind Discs)(With the thinner seal, you can fit two on each side)
O.D: 88.90mm = 3 1/2"
I.D: 63.50mm = 2 1/2"
Thickness: 19.05mm = 3/4"
Momentum number
63.5 88.9 9.52 NBR BA 5011-7366
63.5 88.9 12.7 NBR BASL 5011-7424
Major/Power Major Brake shaft seal (Behind Drums)
O.D: 85.73mm = 3 3/8"
I.D: 57.15mm = 2 1/4"
Thickness: 12.70mm = 1/2"
Momentum number
57.15 85.72 12.7 NBR BA 5011-1427
PTO Selector Lever Seal (Below gearbox)
O.D: 46.04mm = 1 13/16"
I.D: 38.10mm = 1 1/2"
Thickness: 6.35mm = 1/4"
The order numbers quoted and the material list is for swedish company "Tools Momentum", they supply seals and bearings amongst other things...
Thank you Foxen for your input.
I've made a start. Se for the result:
http://people.zeelandnet.nl/hmdetroije/ ... arings.pdf
I will use pdf and put it on my site, so I can update it any time. I have sorted them on the fordson part number for a start.
Please give your comment for improvements.
I could also put O-rings in it.
If you have any data you want to share about seals and bearings. please sent them to me. The fordson part number makes it easy to find it in the book. I have no other books than from the major so it will be hard for me to check the other models.
Any ideas about a place to put the link on the fordsontractorpages?
Foxen, could you check your data please.
Grani
Post by Grani »
This is a great help to me finding out where these might fit. I think they are Fordson seals but i don´t know to what model and place. E27N is on some of them.
Foxen
Post by Foxen »
henk wrote:Thank you Foxen for your input.
Neat little list, but does the major and power major really have two seals on the brake shaft? the measurements I have should be for the one that's nearest to the drums in that case(outer?) Looks good anyway :)
Edit:
Spotted a small mistake on the "type of seal" column, you've typed B1 on one seal?
Foxen,
It has two seals. As you say the outer one is behind the drum and the inner one is at the rear end side.
I have mixed them up but it's correct now.
The bearing is correct.
Foxen,
I have found the two with the numbers.
4245 belongs to the rear axle. page 80 partslist.
7305 belongs to the raised PTO. page 126 partslist.
Could you plaese give me the sizes.
Foxen
Post by Foxen »
henk wrote:Foxen,
I suppose you mean Grani? ;)
I've swapped my seal for the Raised PTO but I didn't measure it when I changed, it's a reinforced seal though, made to withstand very much abuse...
BarryM
Site Expert Team
Site Expert Team
Post by BarryM »
Grani,
Give me a list of the E27N Seal Numbers and I should be able to identify them for you.
BarryM
Kiwi Kev
Post by Kiwi Kev »
Henk
Great idea.
The rocker cover decompression lever seal is
1"3/8x3/4x1/4 single lip
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Thanks,
I will ad it to the list.
Anyone know from when on the decompression lever was fitted to the front?
Frans
Post by Frans »
Henk,
I will mail you my drawings (sorry I dond have them all anymore) my wife made them in Coreldrow but I dont know how to convert them.
If she has some time I will mail then again
Frans
regards Frans
1964 NP Super Major
Grani
Post by Grani »
BarryM wrote:Grani,
E27N4245A
E27N7305A
BarryM
Site Expert Team
Site Expert Team
Post by BarryM »
Grani,
E27N 4245A - Rear Axle Shaft Seal. Suits 1945-1964.
E27N 7305 - PTO Shaft Seal. Suits 1945-1964.
Also suits Upper Extension Shaft ( All Models with
Raised PTO).
BarryM
Grani
Post by Grani »
BarryM wrote:Grani,
This is good news because mine is leaking. :lol: Then I don´t have to buy a new one.
Grani
Post by Grani »
There it went :lol:
Gubbels
Post by Gubbels »
Henk,
I have found the sizes of bearings and seals of the belt pulley you've asked me a while ago.
1x SKF bearing 6210 (50x90x20mm) no seals
1x SKF bearing 6406 (30x90x23mm) no seals
1x seal 65X90X13 R (innerdiameter needs to be a little bit smaller, but you can adjust the little spring inside, 64x90x13 is not a regular size).
1x O-ring 100x6 (I believe the diameter was Ø102 but I used Ø100) Maybe you can use a smaller diameter like Ø100x5, as Ø100x6 did not fit perfectly.
Hopefully this information is enough for you.
Thank you Gubbels,
I put the data in the list.
Foxen
Post by Foxen »
Never thought I'd find this thread again, does anyone know which measurements the seal that goes in the engine block around the shaft which drives the fuel pump has? Mine's developed a quite heavy leak :/
Foxen,
Partnumber 66610 on a Major?
Than that will be 20 x 47 x 10 single lipped with dust lip
Foxen
Post by Foxen »
Thank you Henk :)
Grani
Post by Grani »
I thought the 590E had the same but the one I have is 20x47x12,7 :scratchhead:
Grani,
Cant find that size on this site, only 10 mm.
http://www.detechnoshop.nl/frameset800.html
Foxen
Post by Foxen »
If anyone is interested I've sourced the seal henk gave me the dimensions for from "Momentum", the order number is 5003-8505
I can confirm that it's 10mm thick and has a dust lip, it being 10 or 12mm is of no concern as materials and such has improved quite a lot in the 48 years that have passed since my(ex mine) super major has been manufactured ; )
To find the list on an easy way, I have made a wiki with a link to the list.
This was also to see how to make a wiki.
