Chug-A-Lug wrote:Is it correct that I will need to remove the fuel tank to extract my throttle rod?
Thanks all
Sorry but pretty sure you need the tank off to get the vertical rod due to the bulky cam at the bottom. The area between the tank and steering box is quite tight.
