Work loads
Work loads
I always say work your tractor to try and sort out engine problems. Today I have had Dotty out working very hard and it was a good test for her.
She tends to run warm but not hot normally on the topper, the needle gets up to the 175 mark on the dial and stays there. Today I tried an experiment.
This is my topper, just a little less than 5'
and this is the crop I was cutting,
Ann and I are building a wild flower meadow from an old meadow that was over grazed and "poached" by cattle's hooves. We are slowly clearing a major dock infestation and are building up quite a selection of wild grasses, cowslips, primroses, rhododendrons etc. We tend to let the grasses grow and seed before cutting down. To date we have used the topper but this year we are going to get a few bales off it with any luck.
Dotty went into the edges of the crop to cut a roadway for us to walk around.
In second gear she went very well and would even take it in third. The temperature usually goes up fairly quickly using the topper but this time I borrowed Henrietta's pressure radiator cap instead of the standard Dexta none pressurised one. The temperature staid in the yellow area of the dial.
Fueled with this convincing finding I decided to really push the boundaries. I needed my pumpkin patch rotovated, a job normally for Nuffy. The land has been ploughed and levelled down but has a good covering of wild garlic which is a bit of a pain.
I hitched Dotty onto the E60 which is a fair load for Nuffy and I changed the gearing on the rotovator to the low gear I use with Henrietta.
Nuffy's gears, Big gear driving small gear - high rotor speed -saps power.
Henrietta's gears. Both the same - slower rotor speed - works better for lower HP.
Dotty handled it but it was too much of a load for her and the temperature rose up to the 175 point. It held there but the wide rotovator was not good for her. It did clear her out though and the governor got a fair bit of work. I will not be trying it again though.
She would handle a n E50 or one of the smaller ones without a problem.
Another improvement to her cooling system would be a fan shroud. Dotty's was taken off for some reason, in New Zealand. I shall certainly be getting a pressurised cap for her once I can find one of far better quality than is being offered at the moment.
Post by Bensdexta »
Are there any drawbacks to a pressurised cap? eg More chance of leaks? :?:
Nevis
Post by Nevis »
From my experience the fan shroud (and therefore flow of air through the radiator) makes a huge difference.
My Dexta did not have a fan shroud when I got it and it used to overheat with a 5 foot topper but since adding a fan shroud and a second fan blade it goes up to just under 175 and sits there whatever the load and whatever the air temperature.
It is noticeable that after hard work the top hose is very hot but the bottom hose is still cool to the touch.
Andy
russelm
Post by russelm »
I would expect the fan shroud to make a huge difference to, without it a large percentage of the forced air will jst spill from the side and not do any cooling what so ever as the air takes the route of least resistance.
Mark
Post by Mark »
Bensdexta wrote:Are there any drawbacks to a pressurised cap? eg More chance of leaks? :?:
I put a 4lb pressure cap on mine with a home made shroud (can't locate one over here) and it works great. You don't have to worry about leaks if you got everything done right, and by the looks of your tractor it is. :)
See ya
Mark
