From right to left,The Selene power Major, the Super Major, The County Super Four, and the one that got me hooked….my Dads 58 Major.
Pat
I would not do that because the oil prevents the water from evaporating when it sinks down to the bottom beneath the oil. If the oil is drained the water evaporates and get condensed on all surfaces the whole time and everything gets corroded much more.Supermanuel wrote:I would drain the rear axle and take the oil in a tight drum. You can drain in the spring all condensed water from the rear axle and fill the rear axle with the oil again.
But surely if you drain the oil out, you would leave the bung out.Grani wrote:I would not do that because the oil prevents the water from evaporating when it sinks down to the bottom beneath the oil. If the oil is drained the water evaporates and get condensed on all surfaces the whole time and everything gets corroded much more.Supermanuel wrote:I would drain the rear axle and take the oil in a tight drum. You can drain in the spring all condensed water from the rear axle and fill the rear axle with the oil again.
Leave the oil in place and just drain the small amount of water in the spring, that has separated from the oil during the winter.
