At last a result! just need parts now
Well finally got the sump off of the engine and found the reason it seied up. Some how I don't know how I managed it I managed to bend the oil pump pick up pipe when refitting the sump. This caused the pipe to hit number 3 con rod bearing and break off resulting in no oil. On the plus side only number 3 con rod bearing picked up. I'm going to have the crank reground anyway as the bearings are all standard size. But heres my main problem. Where would I be able to buy or get a pick up pipe to replace the one I mangled? Everything else in the engine looks remarkably good and with very little wear. I'm a lot happier than I should be seeing as it was my own incompetence that caused this cock up.
Re: At last a result! just need parts now
Hello.Go to the parts swap forum here and look at the "shipping cost forum" and probably G man in South Carolina has the part you need. Regards. Salvador
HiMillwall Paul wrote:Well finally got the sump off of the engine and found the reason it seied up. Some how I don't know how I managed it I managed to bend the oil pump pick up pipe when refitting the sump. This caused the pipe to hit number 3 con rod bearing and break off resulting in no oil. On the plus side only number 3 con rod bearing picked up. I'm going to have the crank reground anyway as the bearings are all standard size. But heres my main problem. Where would I be able to buy or get a pick up pipe to replace the one I mangled? Everything else in the engine looks remarkably good and with very little wear. I'm a lot happier than I should be seeing as it was my own incompetence that caused this cock up.
I have seen your problem before on a major about 20 years ago
Hi, I'm guessing thats how I managed to do the damage. I'm feeling lucky in that I got off lightly with the ammount of damage it did to the engine. I'm just finding it a bit hard trying to locate a new pick up pipe. I might well end up making up a new pick up pipe myself as they seem very elusive to get hold off. Oh well you live and learn. I'm just happy as it could have been a whole lot worse.
Hi Paul, I have one on an old block but not sure where you are located, I understand to ship to UK is expensive. I have a picture on my camera if you have any interest, it has some rust on it but believe it would be fine after clean up. Good luck.Millwall Paul wrote:Hi, I'm guessing thats how I managed to do the damage. I'm feeling lucky in that I got off lightly with the ammount of damage it did to the engine. I'm just finding it a bit hard trying to locate a new pick up pipe. I might well end up making up a new pick up pipe myself as they seem very elusive to get hold off. Oh well you live and learn. I'm just happy as it could have been a whole lot worse.
Gman: 1959 Power Major
Hi Gman
How much would you want for the pick up pipe and what would shipping be to the UK England please? Also could you send me a pick of it please so that I could make sure it was the right one for my tractor.
